Hi Guys.
I'm sure some of you used Daniel Stern Lighting upgrades.
I'm about to order a full upgrade set for my GTV6 and he asked me a few questions i thought you guys could enlighten me better.
I'm getting a full set of head lights, 2 inner and the 2 outer, also a complete harness made by him with all the top notch relay needed.
Here's what he asked.
If you would like to have a built-up/ready-to-install harness, I'd like to please have some measurements from you so my harness builder can put together a nice, neat harness for you. Pick out a convenient headlamp relay mounting location, usually on the radiator support panel or one or the other inner fender. The relays with their mount bracket/terminal blocks take up a space totaling about 1.25" deep, 2" tall, and 3.5" wide (for all the relays, not for each relay).
Make these measurements not in direct straight lines, but rather along the paths you intend to run the cables:
Relay mounting location to power pickup point (one or the other end of the battery + cable, usually, but could also be alternator B+/BAT output terminal)
Relay mounting location to good ground (usually one or the other end of the battery - cable, or could be alternator bracket or housing, etc—not just nearby sheetmetal)
Relay mounting location to terminals on back of left headlamp(s)
Relay mounting location to terminals on back of right headlamp(s)
Left headlamp terminals to nearest good ground
Right headlamp terminals to nearest good ground ""
Any recommendations?
I am also planning on removing the dashboard to see if i can see where the cold air is coming in from and cover that if possible. Heating is working very good but i have a very cold draft coming in to my feet.
If that helps with the wiring and relay installation, good.
