Hi All,
I'm halfway through an original resto on my S4 Spider and whilst changing the scuttle drain hoses (that went surprisingly easy!) and whilst there and whilst working around the fuse and relay box, I thought I'd have a go at sorting out the courtesy lights operated by the Sipea 0679 relay.
The relay is tested and working and when voltage is applied the contacts all operate as it should. The wiring into the fuse/relay box is all correct as seen below:
The door pillar switches are new and tested and the doors depress the pillar switches when closed. I have even watched the solanoid working with the cover removed:
The courtesy lights are wired up correcly and they work as they should.
The problem is that when everything is connected up the relay activates even when the door is closed and stays on and activated and keeps the courtesy lights illuminated when the rocker coutesy lights are in the correct (central position) and they do not go out even after many minutes. I have tried several known working relays from friends S4 Spiders (they all still work on their cars when I return the relay) and still its the same issue.
I have even tried a work around that just switches the courtesy lights on and off when the door is opened and closed with the courtesy light rocker switches in the correct position, as below:
The last thing I did was check the wiring loom and there are no obvious alterations or mods to the loom. There are are no worn wires and to be honest I am at complete loss as to what could be causing this problem?
If anyone has any ideas what so ever I will gladly listen as I am completly baffled? Oh and yes I did check that both courtesy lights were wired up correctly ... at a complete loss??
Best to all P
Best to all P
