I wanted to check the integrity of my o-ring seals before I finished my 2L
engine build. So I assembled the engine just far enough to do so. The head was
on along with the front cover and H2O pump. I then temporarily installed
the TA and hooked up the radiator. I used a piece of hose to connect the heater ports together. I then borrowed a cooling system pressure tester to pressurize the system (after filling with H2O of course). After 1 hour at
11 PSI I saw no signs of leakage. Now to finish up assembly!
