1 - 5 of 5 Posts
Do the rear deck speakers come out from the top or the bottom? I had to go into the passenger door to fix a window regulator and add relays (more to come on that. I now have a fast window. Will document when I do the other side) and the speaker was almost totally gone. No surround left at all and the paper cone wasn't much better. I found a Sony speaker at Wal-Mart that is a near perfect fit. But now I probably should replace the rear ones as well since they are probably even worse off.
Sent from my LG-SP200 using Tapatalk
Simple to remove from above. Pry off the plastic covers and the mounting screws are easily removed.
Thanks! I didn't want to pry them off only to discover they were bolted in.
Al
Thanks Jim. I'll keep that in mind. I really just need to get the grills off right now to see if they are as rotten as the door speakers were. I am assuming they are even worse due to sun exposure.
Al
1 - 5 of 5 Posts
