Hi,
My side power mirrors no longer work on my 94 'LS and I can't seem to find the location of its fuse.
Any ideas?
Thank you!
Hi,
Any ideas?
Thank you!
Fuse 24 (F13) bottom row r/h corner one.
Thanks for the response!
Weird, that fuse checks okay. The adjusting function and fold-in function don't work on both sides, are there are other fuses/relays that should be checked? Or could it be something else?
Thanks again
I have the same problem some times, that none of the adjustment works or the folding. However, since it is not all the time it is like that, I have not been able to find the cause.
Interesting, Maybe it's the switch with bad contacts?
I have tried another, working switch, same result. I guess there is a connection issue further back in the system. Right now it works, after the car sitting still for 6 weeks, while I drove the Lancia.
