I bow to the collective..
Here it goes...
1986 Spider V, 74k miles.
Owned the car the past two years. Prior to finding this treasure, the car sat in dry storage for roughly 19 years. Its complete and generally unmolested.
Will say thus far its been an adventure. This is my first Alfa.
Ok, what brings me to the collective.. The car has been my daily driver for the past year. It has not been without issue but to this point I've been able to work through any drama. Last week however it finely bit me.
In general the car ran good. Only real "known" hard broken item was a dead VVT circuit board. I manually pushed in the valve plunger in with a rubber block. Outside this, the car ran fine and I was happy. It did however have a few random interment issues like fuel pump relay crapping out and an odd random burbling or hesitation at engine speed above idle when warm.
My year long solution for the fuel pump relay (the long hard-to-find one) was when it acted up, reach over my right shoulder, flip the deck open, grab the relay and smack it on something. It worked, the pumps came back to life and I was on my way. One interesting common with the relay issue seemed to be the weather. High humidity for a few days and the relay was sure to act up. Last week after the relay crapped out twice and thus beating it silly, I decided to do some exploratory surgery on the beast.
Well, as suspected, it had a nasty little spot of corrosion on the PC board which went to an outbound thermal that linked it to the small relay that feeds power to the big pump. Got it cleaned up and didn't make it any worse,, Yay!
Ok, the test,, with the relay cover off I could push the relay arm with my finger and all pumps ran great. Excellent I thought so I put the cover back on the relay and put everything back together. Well ****, after putting all back together it didn't work. Long story but in the end I found the ground for all this mess, the one screwed into the sheetmetal next to the FI computer, to have a bad crimp and corrosion from old age. Fixed this..
One more time,,, This time I hit the starter and she started right up, I was happy! I cleaned everything up as it warmed up. At this point I discovered the burbling or hesitation I mentioned earlier had now become a interment constant, in other words, once the car warms up it runs seriously crappy that comes and goes. It acts like as soon as the thing kicks from start mode to warm run mode something is wigging out in a strange manner. Sometimes it will rev fine, sometimes it wont. if you hold the throttle at a steady state it will burble and hesitate randomly then clear up for a sec. Again this is the same type burble I mentioned earlier, this time however its a constant hard failure.
I don't and cant afford to just swap parts. The L Jet seems simple enough, what has puzzled me is the randomness of the failure. Its like an sizzle or sparking then clears up for a sec. Engine doesn't shut down and it idles fine.
Lastly, my vacuum lines are good. I've check all the grounds I can find. Fuel pressure was ok last time I checked. The pumps seem to be fine.
Forgot, can the O2 sensor cause this type of problem? If so can you test by shunting the circuit with a resistor, what value?
Here it goes...
