Yesterday I adjusted the alternator belt per the shop manual and found that the bottom bolt wouldn't torque down at the end of the process. I'm old
and I don't think strong enough to but maybe...snapped that bad boy or is there a backing nut that I can't see or probably ever access? Looked to me that the bolt just goes into the block / casting. Still seemed to be threaded just not tight; top bracket nuts are fine. Risks???
Just checked...had no effect on my horrible start-up squeal
but volts seem slightly over 12 now...and the driver's door adjustment I was so proud of failed overnight too
But those old Saab steel wheels I bought off of CL actually do fit (thanks to Rim Crossover at Wille R. Duetto) so I'm batting .333.
