Your car is definitely a US spec car and was originally fitted with Spica injection, like all Alfas sold in Canada after 1971. The underhood photo you previously published shows that your car was converted using a Euro spec Weber manifold, which is the best way to do it. If you want to go back to Spica, it also means you need to replace a lot of hardware, plus the cost of a rebuilt pump - we are talking thousands $$$ here.
As others have said, first tune your Webers properly, there is no reason they should run that rich. I have a bunch of spare jets if you want to try.
I just reinstalled the rebuilt Spica pump on my GTV: the main difference is +15% mpg compared to Webers (9 l/ 100 km in daily use). Webers are simpler to deal with, especially when you want to extract more performance using different cams, head work, etc. I once commented that Spica and Webers are like using a Mac or a Windows based PC. The Webers will work OK most of the time, but you will have to fiddle with them once in a while. Spica works well all of the time until something major happens, which is really not often, but then you are in trouble.
Edit: But I'd pick either system waaaaay before I would consider running an old car with Bosch injection. Reliability and performance of an old electronic system depends on a number of sensors and actuators, many of which are NLA, and of corrosion free connexions. And on a S3/S4 Spider, it makes the engine draw air through a straw and muffles the induction noises to make it sound like a Tercel. Geee.
