I'm getting ready to order a set of custom shocks and convert to coilovers but I need the stock extended and compressed length measurements, front and rear.
I'd appreciate it if anyone has a set lying around if you can measure them.
Chris
From GTV6
Here is the info from a set of Koni Yellows on my GTV6 race car.
rear
uses 10 x 1.00 mm pin mount top & bottom
closed dimension is 16-1/4" mount to mount
Open is 23" mount to mount
Fronts
Tab mounts
Closed dim. 11-5/8"
Open 17-1/8"
Greg
rear
Fronts
Tab mounts
Closed dim. 11-5/8"
Open 17-1/8"
Greg
Awesome! I appreciate the help
Bilstein lists the dimensions as
Front
11.02in collapsed
16.54 extended
Rear
14.33 ext
22.05 coll.
You may have to take a closer look at how the measurements are made to spec the right shock.
