Prepping for a transaxle changeout here with my son's GTV 6, the 15mm halfshaft flange bolts are known to be tough to break loose. I managed to get a few out with a u-jointed socket and short breaker bar, until the socket split.
Knowing physics is on my side, I bought a 4 foot long HR steel bar, 1-1/4" wide by 1/4" thick, and a 6 point 15mm impact socket. I cut about a third off the height of the socket, and slightly ground down the face to get max engagement with the flats of the bolts. I bored a hole through the end of the bar so the socket could be welded on both sides. Our daughter's boyfriend welded the socket for me, and did an excellent job! I then beveled the end of the bar and ground it down close to the socket OD to fit up in that tight space around the flange.
Needless to say, physics won out in the end. I had six bolts that were very stubborn, but they popped and yielded to that long bar and socket! I got the bar as close as possible to the face of the bolt to prevent it from camming out, like a wrench might do. So make yourself a tool, if all else fails. And don't forget the penetrant Kroil, is your buddy!
