1979 Alfetta MM
Ok I searched the forum to no avail.
Is the shifter rattle caused by the bushing where it joins the selector rod or is it internal to the shifter?
On my 75 replacing the bushing at the selector rod cured the rattle and inproved the gearshift dramaticaly
Good luck
I think that you have to go under the car, grab the shift link and move it around to see where the looseness originates. There are a few places in the isostatic linkage that can wear enough to create a rattle. I had a bushing worn so badly that it was hard to select first and second gears.
Hi NM...
I had the worst rattle known to mankind in the shifter mechanism... It was pulled apart and there was wear in all sorts of places but mostly the bushes...
A shopping trip to Performatek cured it!
