Is this the correct order of assembly for the sliding oil caps around the shifter? From the parts diagram I can't tell if the rubber piece goes on the top of the stack as pictured or if it goes between the 2nd and 3rd caps?
I've got a rattle I've been chasing, I replaced the missing rubber piece but still have the rattle, not sure I have it in the right spot (between caps 2 & 3).
washer order
Greg,
I consider that very dilemma just before starting "the project". Here's the way I removed mine (a 1000 words).
Greg
Perfect, thank you sir!
That's how I have it assembled, based on my interpretation of the parts diagram.
Now I'm wondering if I have the shift lever seated properly. Maybe a little transmission oil on the caps to lube things up?
washers
P M sent
