I've just completed a 2,000 mile tour in the Midwest (Minneapolis to Lexington and back: MN, IA, WI, IL, IN, KY, OH, IN, MI, car ferry to WI, MN) over the last 10 days. Had a great time at the AROC Convention and an even greater time driving the Alfa with the top down in broiling heat. Funny, I never noticed the heat so long as I was going 60+ mph. Mechanically, everything went smoothly, with two exceptions. The first was a bit of hesitation when accelerating from a stop (this I attributed to < 10% ethanol in premium gas, something that isn't an issue in MN or WI, where non-oxygenated (ethanol-free) premium is available). Once I was back in WI/MN, fresh 0% ethanol gas largely eliminated this problem. Still, the Webers and/or ignition circuit may need tweaking.
The second problem became an issue the last two days of the trip. I had a difficult time putting the Alfa in reverse gear. No problem going from 1st to 5th (other than an occasional 'nick or notch' in shifting gears, particularly when cold), and the clutch seems to be in fine working order (minor squeak when engaging the pedal). No gear oil leaks. The Spirax HD 80W90 was changed 6,000 mi ago, so that's on the next maintenance list. There is also a 'buzz-rattle' from the shifter, particularly in 3rd and 5th, less so in 4th gear. If I grasp and hold the shifter, the buzzing is reduced. My shift knob rotates freely on the shaft. Sometimes if I rotate the shift knob a few degrees, the buzzing is reduced a bit.
The difficulty in shifting to reverse is quite pronounced, even when proceeded by touching the other 5 gears. The springy 'down and over' action when shifting to reverse is not as it should be.
I suspect that the reverse lockout mechanism is the source of the problem. Has anyone had a similar problem, and is it a common one? What's the most likely remedy? Is obtaining any necessary parts going to be a problem? Any other ideas? I'd appreciate any feedback from those of you who may have dealt with this issue. Thanks.
