Does anyone have a rubber seal that goes on top of the upper sliding disk and the thin metal washer below the shifter rod? I have a few rubber seals that were presented to me as the part in question, but both different. One looks like it should be the correct part, but it's pretty narrow for what it seems like it should be. The other one is larger and cupped. It looks more like the grease cup that goes on the pivot ball of the clutch fork. The inner opening is about the same on them. Then I have a third one that is slightly larger around, and to me seems a little too loose on the shifter mount. On top of all of this, when I pulled back the boot from the shift tower, I noticed that there were 3 sliding plates- one larger bottom plate, and 2(!) upper plates stacked together. Has anyone ever seen this? This is craziness.
