when ever i accelorate hard in first or the car chugs in it i hear a lound noise which i believe is my shift selector bar hitting my driveshaft at the point where the bar meets the lever on the gearbox. i can see that when the car is in first, the bar rubs on some of the surronding are that would be the floor in the middle between the 2 front seats. i just put the gearbox back in and this didnt happen before. what am i missing? any hints? thanks for any leads!
Is it a GTV-6? You may have bolted the shift rod on to the wrong side of the piece coming out of the trans. I believe that it bolts to the out side.
Paul
If this car is a non iso gtv6, the problem could be in the attachment of the shifter rod to the transmission control shaft.
When the transmission (or clutch) is replaced the correct spline position must be marked between the rod coupling and the control shaft. If this part misaligned your rod can impact the drive shaft.
If someone did this for you have them fix it!
