Shield gas setup
1055 Views 2 Replies 2 Participants Last post by  chairmankaga
I just started using shield gas this past week now that I'm getting into visible bodywork. I have simple Lincoln Weld-Pak 110 with the optional gas setup and a 40 cu ft bottle. The gas kit didn't really have any instructions aside form how to rig up the solenoid and bits inside the welder, but I have experience with SCUBA gear and figured a regulator is a regulator (SCUBA regs are pre-dialed in). I tightened everything down and went to town. First off, WAY easier than flux core work. I can actually see the pool and move it smoothly. Fun!
Anyway, I had worked for about 20 minutes (actual weld time) and the bottle went dry. I'd read a 40 bottle should last at least an hour, so I figure I either have a leak or I've set up something incorrectly.
Any advice on how to diagnose? Or any other suggestions?
try dialing the gas down till it's not fun anymore and you get spatter
It was a burr in the bottle's valve... they graciously gave me a free refill.
