1 - 2 of 2 Posts
After blowing up my 33 16v 4 months ago she breaths again:)..
I managed to get a engine from a series 3 cat model, mine being a pre cat.
The only thing is it just doesn't seem as quick as before:confused:.
I have a few questions if you guys could help me.:
Was there a difference between the cat engine and non cat.
There seems to be a slight misfire i have put new plugs and leads, rotor arm and dizzy cap, but it still idles a bit rough and performance is not right you can feel it pull strong then not so strong almost like running on three cylinders, i have tested the resistance on injectors and they are all within 0.2 of each other the average being 16oms?. Do you guys think i could just have a blocked injector:confused: i unplugged injector 3 and the idling just stayed in the rough zone without the smooth, plugging it back in made the erraticness come back.. could it be a dodgy injector..
Hope that made sense comments appreciated.
Rich
could be an injector fault, another good indicator would be a compression test, very difficult to do on a 16V though. Id start with removing the injectors and maybe get them cleaned and tested. Also sheck for any wiring that may be hooked up the wrong way, a loose earth for the injection can reek havoc.
1 - 2 of 2 Posts
