1 - 20 of 39 Posts
Hi guys - this is the donor car that came with my '66 Stepnose. It is severely rust but somehow as not managed to collapse in on itself yet. Every single panel is bad, you'd have to literally replace every panel including the inner sills. No title, although one couple probably be obtained in a month or so.
I am going to hold on to the 1750 long block, and unless someone makes an offer the suspension and differential and transmission. Steering wheel will be coming off and could be repaired.
I wanted to offer it here before it was recycled in case anyone is seriously heroic. If no one takes the full shell then please let me know what bits you need or if you see a panel that will help you.
I'll take pictures of both those areas tomorrow in the day light.
Robert - do you need any surrounding metal as well?
Just out of curiosity, what material are these strip on the package tray make from? Mine were missing when I got the car.
Hi, I'm looking for the panel that's underneath the rear parcel shelf - it looks like you have a pretty solid one there.
Someone cut mine out to make a bass cabinet. Here's a picture of how it looks today. Any chance you could cut that out?
So impressive that even a car as far gone as this one can help others.
Re brake booster bracket.
I would need the surrounding metal edge also that fixes the bracket to the body.
I do not have this bracket on my car and need to weld your one in place on my car.
Robert
Good (early morning). I should be able to get that cut out, will take pictures this am and then we can mark up the section you need.
Discussion Starter #12
Robert - this section, correct? Paint is scabby but metal is solid.
Not sure how expensive shipping will be, happy to help but have you estimated cost? Won't be heavy, just bulky.
Discussion Starter #13
Hi - this section?
Hi,
No, the horizontal section that's under the rear window. Someone asked you about the tape on there - that piece that makes the rear shelf.
Any chance you can just hang on to it and I'll pick it up one day when I come to LA?
-Richard
If it's not terribly rusty, I could use the battery tray bracket. Cut the fender well and I'll drill out the spot welds.
Discussion Starter #16
Hi,
-Richard
Ah, yes. Happy to do that.
Discussion Starter #17
Discussion Starter #19
Front suspension and trailing arms are spoken for. Top of the deck here is as well, anyone need the lower section?
Discussion Starter #20
Quick update - the car was mostly stripped yesterday so the suspension parts will be available this week to those that pinged me on the bits. Ditto for body parts.
1 - 20 of 39 Posts
