My engine was recently redone (Poland) but does not runs very well. High idle, runs rough etc...
I have tried everything tuning the SPICA inj but need to go back to basics and make sure the cams are timed right (I have timed ignition.. just havent done cams out of lack of knowledge and know-how).
Here is the information I have.
- The cams are not stock. The last PO put Megacycle cams in this 2L engine (PO had the whole engine redone by Hasselgreen Race Engines in SF).
- I had Megacycle send me the info on the cams.
- Picture of Timing marks on cams and journals.
How should I time my cams ?
The specs show degrees but the engine is in the car and cant put any degree scale on transmission shaft etc..
Are the knotches in the cams meant to line up with the knotch on the journal (cams are not stock) ?
Why on the admission side are there 2 knotches on the journal ? I assume one has been added (Hasselgren race engine prepared the car in 1995 for PO).
My mechanic in France isn't sure how to set the timing on these.. any help will be greatly appreciated !!
Roland
Roland
