Hello
I' m drivin a Spica injected Spider for nearly five years now.
Last weekend a friend of mine stayed at my place and naturally we did talk about Alfa, and about settin the fuel mixture.
I always did set the fuel mixture according to the numbers Wes Ingram is giving in his manual, using a gasanalyser. I always did the setting with the airbox off the engine.
My friend meant if the numbers given were supposed to be measured with the airbox on the engine that this would make quiet a bit of a diffence.
Because the airbox will reduce the breathing capacity of the engine, and so richen the mixture.
Any Ideas?
And what would be the difference measured in CO?
Or are they supposed to measured with airbox off?
Even the factory manual is not stating this one clearly.
Greetings from Germany
Bernhard
What color are your spark plugs?
Does the car run well?
I talked to Wes.
Fuel settings are supposed to be done with the airbox on the engine.
Bernahrd
