Rob,
My fuel pump is audible only when the car is running hence it fires when the key is turned to start it. It does not run with the key in any other position. First click I get all idiot lights, radio etc., second I get ignition with the pump on.
I believe I may have seen your post in the AD also (?). Not to be redundant, but have you confirmed flow through the pump under the car before the fuel rail? Then at the rail? I presume you have spark after the coil. I ask this as last year at Limerock, a guy had a GTV with a no start and he assumed he had spark and looked for other gremlins. I pulled the coil wire, had him pop the motor and no spark. He had fried his electrinic ignition.
FWIW ....
Rob
FWIW ....
Rob
