First time seperating a manual 164 gearbox from engine, the gearbox and engine are QV (S), removed starter motor, removed flywheel bottom cover, removed intermediate shaft, removed all gearbox to engine attachment bolts, gearbox will not seperate from engine anymore than as in the attached photo, about 3cm, am I missing something, any tricks, does it just needed a good hit with a hammer?
Thankyou Graham, I will try that now :)
Graham, you are a legend!:)
Any tricks with removing the clutch?
How does the throw out bearing remove?
Use two plastic "credit cards" or hotel room "plastic key cards and with pressure plate off flywheel wedge plastic cards around TO brg hole in pressure plate to retract teflon conical ring and metal snap ring. Then pop out TO brg.
