Hi all,
I'm looking at the options for aftermarket ECUs for a 2.0 twinspark from a 75 - being transplanted into a 105 running carbs. Can anyone give a quick list of what sensors are going to be left on the bare motor once the fuel injection setup has been removed.
I'm thinking the following - can someone suggest any others - or even better point me to a diagram.
- The AFM will be gone.
- Coolant temp.
- Oil pressure - but where is it located?
- Reluctor sensor on crank
- Oil level (is the one under the dizzy?)
Is there any timing sensor on the cam I could use for a sync - or has anyone made one? Perhaps using the upper dizzy?
Many thanks.
- Coolant temp.
Many thanks.
