You may get a lot of responses. I just did the head on my 89 Spider due to burned exhaust valves. My thoughts:
* Knowing what you're looking at is important, so read up, and poke around here, if you haven't done this before.
* Work methodically, noting where everything goes, and how it all fits together. Take notes, pics, make diagrams. You'll be amazed how obvious it looks when it comes apart, and how clueless you'll feel two weeks later when you try to put it back together.
* Be clean, and bag and label all your parts and hardware.
* The head may be difficult to lift if it's corroded. Maybe you'll get lucky, but the factory head removal tool is sometimes essential.
* Figure out why the head gasket was leaking. Was it improper torque, overheating, old warped head, cracked head, liners too low, or what? If you don't find and solve the problem, it may return.
* Hold the liners down with the factory tool or a tube and nut once you get the head off. Don't rotate the engine at all without clamping the liners.
* Put in roll pins in the six oil passages if you don't already have them; use Viton o-rings in those locations.
* Get head, block, and liner surfaces scrupulously clean before reassembly.
* Bone up on getting your cam timing right, and find actual TDC before doing so; do not rely on the pulley/pointer, as it may be inaccurate.
* Before you actually start the engine, turn it over by hand first, then on the starter with the ignition disabled, to make sure there is no mechanical interference.
* Replace anything that looks marginal (hoses, clamps, injector seals, etc) while you're in there, because it's a much bigger hassle later.
Those are the biggees I can think of now.
