Security / Alarm System Linked Dash Climate Control Unit!? (Trunk Release & Gas Cap?)
So, this one drove us MAD yesterday! (1995 164 LS in overall good condition.)
The good news is that we located some loose connectors behind the climate control that finally solved our remaining stepper motor issues (after pulling half of the bloody car apart), but here's the current issue!
The trunk release button on the climate control / dash unit operates intermittently. The gas cap cover / flap release also works only sporadically. There appears to be some connection with the security system! "APPEARS" being the operative word here... If we disconnect the battery, remove the climate control display unit, reinstall it, rest the alarm key in the trunk to the ON position, reinstall the climate control, reconnect the battery, cycle the door locks with the key fob, then the trunk and gas cap buttons work. For a little while...
What's particularly challenging, is that we can't get consistent results from our testing! Sometimes they work with the alarm system in the OFF position and sometimes they work with it in the ON position. Sometimes they just don't work at all. We are able to energize the trunk release relay (behind the carpet in the trunk on the passenger side of the car), from the connector end and get the trunk release to operate. The gas cap release has an extra wire and it is not clear what to jump where in order to get it to work via the relay. We are able to simply jump it from the power IN to the power OUT connectors, and then the door releases.
The door does work sporadically from the dash button though. Intermittent operation of both trunk and gas door from the buttons on the dash unit, corresponds with the little lights for each respective button working and not working. (I.E - If you push a given button and it lights up, the corresponding release activates; if the little light on the button doesn't light up, the corresponding release does not operate!)
I can shut the car off, go to bed, and the next morning I'll maybe get a single, onetime operation from each and then nothing again after that... Or not...
