On 102 series, FUSI is ALWAYS wrong.
NEVER, I repeat, NEVER do the chassis numbers correspond to motor numbers on two liter 102 series Alfa models. The first 432 engines were actually left over 1900 blocks fitted with different heads and when the chassis components were finished the first available block was put into it. Only up to 1960 are the numbers both stamped on the firewall plate. Luckily, after 1959 the engine numbers are no longer stamped anywhere except on the engine itself.
That was even true of the 2000 sprint, the famous car designed by a young Giugaro for Bertone. For example, the show car on the Alfa stand at the Brussels Motor show which I recently acquired was hurried to completion on December 24, 1960 (one of five made the first year) especially for that show. FUSI says the 1960 cars should have chassis numbers 5 to 10 (but the car is AR10205*00019). He also says the engine should be between 1 and 10. At least on that he is correct. The engine is AR00205*00008. But on no sprints, just as on no spiders or sedans, were either chassis number or engine numbers assigned in sequence or direct relationships. And even on this very first (or almost very first) sprint the engine number is only on the engine (but strangely, used as the VIN number for the title when finally first sold in San Francisco). It also seems that Alfa would not necessarily assign chassis numbers as the vehicles were finished (at least not on the very first few that were on the first run), but when started. That may explain why some of the first completed cars had seemingly later chassis numbers. They had somehow ended up being finished before others with smaller numbers. Another example of that situation occurred on the Giulietta spider.
