At this point I'll try anything, broomstick it is! I will also continue to try repeated lurching starts once I get the CV joints cleaned, repacked, and new boots installed. They need immediate attention before I drive her again. Anyone know of a source for new CV joints? So far all I see available from the usual sources are the boots...What does everyone out there do if a CV joint is unserviceable?
Also, look at what my wife found when she drilled out the rivets in the front wheel well fender panel
One ounce shy of two pounds of dirt, leaves, and sticks. What is even more amazing is that there was only minor surface rust in there. If you have not done so, remove these panels and replace the rivets with screws!
We found the drain hose inside, but where is the drain hose outlet?
