1 - 13 of 13 Posts
Hi Guys,
I really need some advice.
I am in the process of changing my steering wheel to a Nardi. I followed the forum and used a puller. The puller snapped the mounts off.
Now I am stuck.
I have tried using the screw holes, no success. I have sprayed PB Blaster and tried the hammer trick on the column trick.
Neither of these worked. I am at the point of either destroying the existing wheel or returning the Nardi.
I really could use some advice.
I dont have a solution, but have a couple basic questions:
Is your car a 92 Spider?
Did Alfa change from a tapered and keyed column in earlier cars, to a splined shaft, right?
Of course, you removed the nut on the shaft.
Regardless, keep hitting it with an oil penetrant. It's surprising how that stuff will seep and creep into the stuck area over days, and then it will suddenly break free, like "...hey, what's the problem??!!".
I likewise can't visualize what the "mounts" are. Are you referring to the hooks on a puller?
Using the screw holes is the way to go, at least on my 72 with tapered shaft. I put the screws under high tension, sprayed in Break Free (IIRC); at some point after that, there was a loud bang, and voila, the wheel had popped off.
So stick with it and dont destroy the wheel.
Good luck.
I replaced the wheel on my ‘91, went from airbag to wood. I used a normal puller but used special ace hardware bolts that screw into the wheel. Always keep the center nut on the shaft while using the puller, or you can damage the column threads.
1690122
1690123
1690124
me too, not sure what you snapped off.........got a photo?
sometimes leaving the puller on overnight, real tight (PB blaster and tightening it up a little each hour or so) and in the morning you find the wheel has popped.
(yep, leave the bolt on the spline or you might mushroom it and that's it then!)
worse comes to the worst, the S4 has a UJ joint on the steering shaft just above the pedals;)
disconnect that airbag......even after 30 years they should still work!
I pulled the threads out of my wheel trying to pull it on my wood spider wheel so I tapped them up to 1/4" fine thread and was able to remove my wheel with my steering wheel puller. These things can be on there pretty good.
Good move. Way to go to solve it.
Discussion Starter · #8 ·
Hi Guys,
Thanks for the tips. I broke off one of the two "holes" in the 12 and 6 o'clock position. For some reason I can't figure out how to post a picture.
I'll keep at it.
Discussion Starter · #9 ·
/Users/peter/Desktop/steering wheel.pdf
Discussion Starter · #10 ·
/Users/peter/Desktop/steering wheel.JPG
Discussion Starter · #12 ·
Here is the photo. The thing still won't budge
1 - 13 of 13 Posts
