1 - 10 of 10 Posts
Can anyone with a stock S4 Spider setup let me know unloaded ride height, like at the top of the wheel openings? I made some suspension changes and want to see how it compares to stock, as I might want to shim it a bit. Thanks in advance.
1991 Spider Veloce, 2017 Giulia Ti
My measurements after the deep passenger spring pan, all other suspension stock, 195/60 R15 tires on phonedials. F 27 PSI, R28 PSI........
Front: 24 3/8” or 619 mm
1624768
Rear: 23 5/8” or 600 mm
1624770
The brand new rubber spring pads top and bottom in the front may contribute somewhat to the front measurement?
You wouldn't expect the measurements to the tops of the wheel arches to be the same due to the different shapes of the arches. Measuring under the jack points is a better indication of front to rear ride height.
You do know the thing about observing the angle of the lower control arms to determine how low is too low, right Tom?
Thanks Keemosabe
Yes, and hence my slight concern and confusion: the arms are angled upwards. It's currently got the Centerline springs and no spacers in front, which should be a significant drop from stock, but it also looks to be reasonable height (and measures pretty much the same as the above.)
The CL stuff is okay but I'm thinking to just go back to stock springs+shims as hard springs are probably overkill for the driving I'm doing. And hey, I've got time now to swap stuff around to try a few things and get it all right.
I originally went with CL Springs, the deeper pan and no spacers. On my 1990 S3.5 it was too much - it was as you describe. Yours is maybe worse due to the extra weight of your PS? I put the spacers back in and it's perfect IMO.
With shorter springs, no shims and a deeper pan you should be way lower than stock and the control arms are indicating that. Dunno about body measurements.
Yeah, I'm kind of waffling between just putting in the spacers with the current CL springs, or going back to stock springs (in which case I need to decide whether to use the spacers or no.)
From what I can tell from the parts diagram / shop manual these originally came with a 7.5mm spacer in front, but given Alfa's documentation accuracy if folks have found otherwise I'd like to hear it: I don't recall what was originally in there.
Don't have precise notes -not sure I even measured them - but my spacers are about that.
Yeah, I'm confident on the 7.5 mm, the number in the parts diagram references to a 7.5 mm Alfa part, I was more wondering if the shims were always in there on the S4. Lotta weirdness on these cars sometime (e.g., the S4 parts diagram shows two different depths of spring pan, but apparently they all shipped with the shallow pans.)
So the thing I hate about springs is they always seem to be more art than science.
Pulled the left Centerline spring and found it had a 7mm shim under it (the right did not.) I assumed this was to adjust for the fact that it had had shallow pans on both sides. Now that I have the deep pan on the right, I reinstalled new stock springs with one 7mm spacer on each side. Nope, too low on the left. Redid it adding a second 7mm shim on the left and now it sits level and the lower arms are straight.
Man, those stock springs are long: I forgot that this job just takes freakin' forever with the threaded rod method and stock springs.
Final measurements are 24-3/4" at the front fenders and 23-3/4" at the rear fenders.
1 - 10 of 10 Posts
