1 - 1 of 1 Posts
I am looking at repairing the leak on the power steering box on my '91 Spider. The leak appears to be coming from the seal on the output shaft so I plan on changing that.
I saw the post on replacing the seal on for a Burman box which I assume will be similar to this one.
Can anyone confirm this?
I also found the Centerline sells a seal for ZF box but it lists it for '77 model which was a manual box. Is this the same seal? Does anyone know the size of the seal so I could by it direct from a local bearing/seal shop?
1 - 1 of 1 Posts
