1 - 2 of 2 Posts
After removing both bumpers to access the side marker lights I found that I need 13 of these metal clips that attach the bumper skin to the bumper frame. I also need 4 of the rubber pieces. The clips can be used but the rubber needs to be NOS or I'll have to make them out of 3/8" thick rubber. Does anyone know what these type of clips are called (other than hard to find clips:laugh:)? I've tried googling flat spring retainers and flat spring clips with no luck.
I had an enquiry going on those bumper clips too.......never found them.
I eventually got some for the Hyundai mentioned in the post (they are 30 x 13 mm so not all that different in size externally, but the internal teeth were too close together to push fit over the plastic tang on the bumper.
http://www.alfabb.com/bb/forums/spider-1966-up/207161-spider-s4-bumper-clips.html
If you have more luck let us know!
BTW the part number for that rubber (called a 'Support' in the parts catalogue) is: 60519479
but that brings up nothing either!
1 - 2 of 2 Posts
