1 - 13 of 13 Posts
It seems I have a lot of time on my hands suddenly, so it's time to work on the Spider. On my '84, the under hood light has a self-tapping screw on one side and a plastic fastener plug on the other side holding it in place. Does anyone know if this is correct? Is it supposed to have a screw on both sides? A plastic fastener on both sides?
Thanks in advance,
David
That doesn't look like an OEM part.
Cheers, Jon
Based upon several other non-OEM items I have discovered on this car, I am not surprised... is it supposed to look something like this?
Or, something like this?
The ones you linked to at Centerline and Mr Fiat are original, or at least original style. My S4 has the white plastic one. It takes a bulb that looks like a fuse.
The white plastic one is the correct engine compartment unit. The other one pictured is the trunk light. I bet if you remove the unit you have you'll find a hole under the center of it that the correct part screws to.
I replaced the light fitting on my 1986 Serie 3 a little while ago. Here you can see the old and the new. The old was damaged. The new is an original Alfa Romeo part.
Jeroen
Thank you for the very clear photos. Follow up question: does anyone know about a source for replacement bulbs?
These are on Amazon for $127/10 pack: https://www.amazon.com/Replacement-GENERAL-ELECTRIC-7546-Light/dp/B07957V7ZQ
Would the bulb below work as a replacement? $5.35/2 bulbs is a bit more in my budget...
David
[/URL]
David
$127 forba ten pack seems a bit silly. These are available at parts stores either singly or in two packs. Guaranteed if you buy 10 you wont be able to find them the next time you need one.
I second that - $127 is extortion. There's nothing special about these bulbs, you can get them at any auto parts store. I keep a couple extras in my glove box.
Thanks for the fast replies. I'll check out AutoZone and Advanced. For a while, I thought these bulbs were built out of unobtanium!
very common bulbs
you have them under the hood light, the glove box light and the trunk light.
A pack of 2 for 5 bucks or so at any store.
I think I have replaced one in 10 years!
1986 Alfa Romeo Spider Veloce
Apparently Murphy practices law in your garage/shop as well as mine. <grin>
1 - 13 of 13 Posts
