I've have replaced the firewall and throttle linkage bushings and the throttle rods end connectors on my 84 Spider and now I want to adjust the linkage correctly.
I've found some rather loose guidelines as to how to do this and some contradict each other.
So, I am looking for a post/link that's out there that details this exact procedure.
I know there has to be someone on this forum who has this procedure and is willing to share it.....
Les
*** I guess my main question is, when the throttle rod linkage is disconnected and the spring holds the pedal all the way up, is this the correct starting point to adjust the long linkage rod and ensure the peddle stays at that height?
Les
