can i disconnect this without effecting other electronics and where is it located exactly?
i am fed up with the buzzer. i hate it. i want it dead and ghosted
there seem to be 2 types...depends on year
there were 2 little white gadgets located on the steering column...earlier type
then there was a relay with its own buzzer, mounted on the left inner panel, above/behind the fuse box.
Fairly sure you can disconnect it w/o affecting anything else
easy, just pull a wire from it. Mine was disconnected but decided to hook it up to see how dodgy it sounded. Its annoying as hell, bit ive left it hooked up :)
I am right there with you. I couldn't reach the buzzer but got lucky when I disconnected a black wire, with an in-line connector, under the steering column. The only downside I've noticed so far is opening the passenger door doesn't turn on the interior light. A sacrifice I'm more than willing to make.
Funny,
Our '85 Graduate (flood car from Hurricane Sandy in 2012) has been a journey. Virtually EVERYTHING need attention on some level, with the exception of the "key in ignition lock" buzzer. When I first energized the electrical system the buzzer came on as it should. As annoying as it seems I have a need to keep it in place. BTW, I did change over to Weber carbs and never looked back
