I can usually find what I need at ACE Hardware.
This is a good point. I have an old-school hardware store near me that sells all fasteners individually in bulk (not plastic packages), including high-strength fasteners.Note that most of the cheap-o nuts and bolts you find at the hardware store are low-grade steel. For automotive applications you generally want something of 8.8 strength minimum (and often the even stronger 10.9 for stuff like suspensions). This should be stamped on the rim of the nut or the head of the bolt. Most places cary the higher strength fasteners along with the cheaper unmarked stuff.
Thanks, that's good info. There is a specialty nuts and bolts store near me and they had them! Lucky me!You're in Canada so hopefully M8x1.0 is easy to find up there. Down here it can be a bit tough as most auto stores only seem to carry the coarse M8-1.25
Just something to be aware of.
