Can someone please verify if the low fuel and low oil pressure lights activate on an S3 when the key is turned on? I am replacing my dash lights with LEDs and I need to check these two before I put the console back together. I tried putting the incandescent lights back in, but they still don't light up.
As Eric said the answer is no on the dual pod setup which was up to 1985. 1986 onwards was the monopod which you would have. Hopefully someone else will chime in on that.
