Does anyone know what size machine screw or bolt is supposed to be used in the back hole of the armrest in order to secure it to the door? Mine both have wood screws in them, which I assume is NOT NOS...
Thanks in advance,
David
Wood screws? Not even sheet metal screws? Sheesh. What is on the door, a captured nut?
No capture nut on either side, just what appears to have been at one time a threaded hole in the door. You can see the hole in the photo attached to this post. I'm thinking if I know the original screw/bolt size, I can re-thread the hole with a tap.
David
Hey Eric and Rich,
Appreciate you both taking the time to check this for me. I'll replace the woodscrews with a couple of sheet metal screws which makes a lot more sense.
David
