Hello all,
is there a trick to removing the exterior door handle? I’ve already removed the latch linkage inside the door.
many thanks,
Bob
Bob, yes, you need to twist and turn it just right to get it out. And when you do get it out, remember which way it came out so you can install it the same way.
Both of the U-shaped brackets that secure the handle are removed ? If everything is undone, I found I had to push the handle assembly forward, then lift the rear portion outward, before withdrawing handle assembly from the opening. It's a tight squeeze, to be sure...but it will come out.
