The poor girl is running hot. Coolant levels are fine...could it be the thermostat (of course it could be...)? How can you tell if it's a thermostat problem?
What are the other common problems?
Thanks for your help.
See the other thread under GTVs. Causes of overheating are listed there.
To check a thermostat, remove it and put in a pot and heat it. When it gets to the spec stamped on the unit itself, check that it opens fully. Use a know good thermometer to check temp of water.
Also, make sure that it's installed with the correct orientation and the system bled to remove air pockets.
