Well, I guess this is nothing new to the Alfa world- but my Spider is having issues with running.
I will try and be as discreptive as possible here, but I know even then there are still a myriad of issues that could cause this.
She is an '85 Spider with a 2.0 liter VVT (Bosch) Fuel injection.
I just put on a new starter, intake bushings, valve cover gasket, and painted a few aluminum bits. I also had the tranny out recently, if that means anything.
She is a project car that I have only driven once before this, so I am not sure if it had this problem before I got through working on here this weekend.
So here's the scoop-
After finishing the job, she ran (cold) better than ever before. It doesnt sound like its missing when cold, but when I have driven her half-way around the block, come to a stop at the stop sign, and then take off- after hitting third, she slowly loses power and revs REALLY high and I downshift so that the little bit of power left will hopefully propel me home.
Well, then she completely dies. I sat at the side of the road for a few minutes, then she started up with hesitation. She got me home in second gear all the way at 10mph.
I pull it into the workshop and pop the hood. nothing came unplugged. nothing is loose and all of the sensors and hoses are exactly where they should be. No vacuum leaks (that I can see or hear). She slowly starts and runs for a minute then dies when I try and start her when hot. As soon as I turn the key when its cold, I'm golden. she then takes me to the EXACT SAME spot on the road, then starts the whole cycle over again.
The only thing I can think of are the smallest hoses going into the canister behind the intake are extremely dry-rotted and most likely leaking, but I have no idea where they lead.
I am at a dead end. PLEASE HELP ALFA GURUS!
-JD
-JD
