Hi Folks -
Was looking for some input from the group on a rough idle on a 78 Spider. After warm-up, the engine seems to have a miss when just idling, not terrible but enough to be annoying. Otherwise, it drives well and pulls strong. I did a compression test and saw the following results...
#1 223 psi
#2 200
#3 224
#4 225
Do you guys think the delta between the #2 and the rest of the cylinders could be responsible responsible for the roughness at idle.
I did spray some starting fluid around the air manifold hoses to see if there's some air leak, but no speed-up of idle.
Thanks for your input
#1 223 psi
#2 200
#3 224
#4 225
