Hi,
My wife and I are in a road trip in my Duetto and have run into a little snag. I’m hoping the collective wisdom of the AlfaBB can help me with a fix!
First, let me say I have figured out a workaround, so we’re not actually stranded, just a little inconvenienced. But on our first stop, after about2 hours of driving I found turning the key did nothing except make the “Dynamo” light dim a little. My first thought was a stuck starter solenoid, but I had the starter rebuilt and solenoid replaced about a year ago, and that wasn’t it. Eventually I found if I pushed on the back of the solenoid (picture below; wire to the ignition switch is removed in that photo) it worked every time.
I tried replacing the spade clamp at the end of the wire that goes to the ignition switch, but that didn’t help. It seems like there’s a loose connection internal to the solenoid. When I get home I’ll pull the starter, but anyone got a brilliant idea which will spare me the embarrassment of having to pop the hood every time I have to start the car?
Thanks in advance!
Alex
Thanks in advance!
Alex
