had the BOSCH coil go out and ug i replaced it with this from AUTOZONE
Ignition Coil Style: Conventional
Ignition Coil Terminal Type: 2 x M5 x .8 stud and nut exposed
Coil Wire Terminal Attachment Type: 1 x male spark plug cable and boot
Performance Item: OEM Standard Part
Minimum Primary Resistance Range: .7 - 1.4
Minimum Secondary Resistance Range: 6.0k - 11.0k
Package Contents: Component, Hardware
Vehicle System Voltage: 12V
how much trouble if any is this going to be ...did i really screw the pooch and screw up the RML? by the by been trying to call RML all day no answer left more then one msg....
V/R
Chris
V/R
Chris
