Started tidying up a recent purchase, 1991 12 valve automatic, all windows work great except the right rear, checked fuses, swapped the switch out with 5 good ones no change, I have time to fix today if I can track the problem, can't say I have ever had power to switch problem before, what next?
No, swapped both with known good switches both console and door switches not receiving power.
Check 30A fuses under center console under little carpet area behind switches.
Steve:
Is this applicable to the 24v models also? Three of the four windows have quit working on my 95LS.
Finally got around to checking fuses yesterday Steve after doing a seat swap
Interestingly this 164 did not have the removable carpet area Steve just hard plastic, so removed rear two screws under ashtray to raise the console slightly and locate fuses
Bingo maybe, no, one fuse was actually missing, put in a new one, code no joy!
What next to check electrical experts?
