Last year my quarantine project was to get my '76 Alfetta sedan back on the road. And since all the reasonably priced GTV6s disappeared before I got around to buying one, my project for this winter seems like it should be reviving the Milano that my dad bought in the '90s to replace the Alfetta. Unfortunately it developed some problems, life got in the way, and it's been parked since 2001. Before its hibernation it was actually one of the cars I learned to drive with while getting my license, so it will be nice to get it going again. It certainly doesn't make financial sense given their (lack of) value, but I can't be responsible for there being one less Alfa left in the world...
As you can see, some rust starting in the rear wheel arches, but it was never driven in winter so it's fairly clean otherwise.
Into the shop, which was no trivial task given it doesn't start and there's a bit of a slope to the door. And the brakes don't work, but fortunately(?) it doesn't roll very well either. At this point I was still somewhat optimistic that it would be pretty cheap to make it road worthy again.
The original list of problems included a large oil leak from, I was told, the rear main seal, and no fuel pressure. So I figured I'd start by pulling the motor and evaluating from there. Never having pulled an Alfa motor before, and working by myself, it actually was a lot easier than I expected. Alfa engineers cleverly designed their gaskets to not hold in fluids so all nuts and bolts were nicely oiled and came off easily.
Not unexpectedly, the driveshaft and CV joints need rebuilt and the exhaust is in pretty sad shape. After checking Centerline, my hopes of not spending a lot of money started to fade. Those rubber bits are expensive! Anyway, with the engine out I cleaned up the engine compartment. It always feels better working on a clean car. Oh, and it needs new motor mounts too...
More to come as I wait for parts to arrive and dig deeper. I'm sure I'll need to tap the collective wisdom of the board.
