The revised giulietta is coming about six months after the compact cuv in late 2013. It will be slightly wider and longer than the present one. Since it will be made at the Mirafiori works in Italy, the exhaust system is probably mild steel and should be replaced with 401 stainless using a mandrel bender to fabricate it with Magnaflow components at a custom shop. The stock system fails in as little as eighteen months. Replacement has been quoted at about $300 for the stainless equivalent. I have a design which should work using 2.25 inch pipe to allow the engine to run cooler.
