I have read in Bruce Taylor's book about the possibility of premature reverse idler shaft wear (p. 70-72). I am about to reassemble the power-train and wondering if I should replace it.
Has anyone had wear issues? Has the replacement been relatively straightforward?
Thanks, JP
Thank you for fast reply. If that is more of the case than not, I may elect to not make the cure worse than the disease.....
Thanks, JP
I read that comment as well and think it might be worth looking at the shaft if you have not already. If it does not exhibit wear, I would definitely leave well enough alone.
Mark
