1 - 20 of 25 Posts
I bought her in 1998 and used her as daily transport for a couple of years (businesstrip to Germany in winter is interesting) got a promotion, and a company's car, put the now rather old car in storage until 2012
after stripping and sandblasting she spent 3 years in the welding shop and 2 years in the paintshop, sometimes life has other priorities. the idea is to get her on the road again before spring 2020.
1605104
she was bad condition after 10 years of storage and a lot of bodywork had to be replaced.
1605106
originally red, but almost every 105 is red, so decided upon Blu Olandese AR343, seven layers of paint, two layer of clear coat. interior will be darkish yellow (ocre) leather.
Discussion Starter #2 (Edited)
repairing the steering box.
after dismantling the end bearing of the steeringbox/rod proved to be damaged. This damage is due to disconnecting the ground-wire of the horn. The one that runs all the way through the steering column. the horn will sound but all the current has to go through the steeringboxbearing effectively spark-eroding it away.
it proved impossible to explain to the specialized workshop that only this bearing needed to be repaired. They only wanted to replace them all (at a cost) or none.
So I made a stub and welded this to the end of the shaft.
in the lathe turned it to the correct dimensions to fit a timken bearing
made a spacer to fit the bearing in the box
finished at almost no cost at all
regards A
I love this sort of workaround/improvement. Well done!
What was the Bearing no.?
Looking forward to seeing the progress.
today I started with the brake-lines. To do it properly the steering box and vacuumbooster inc pedalbox had to come out again.
two steps forward and three steps back. which reminds me of the rule of time or planning.
to finish a job you have to multiply planned time by two, and increase the unit with one,
so an one hour job normally takes two days
it took a lot of "picture searching" to get the routing correct. I have thrown away the old ones sometime, can't keep everything, which I regret.
1605337
1605338
if someone has pictures or recomandations about the routing of the fuel line I would be most grateful.
regards A
request for pictures!.
to instal the brakelines under the car I spend a couple of hours scrolling through posts to get the routing right. didn't take enough pictures dismanteling the car so many years ago.
now I want to finish the brakelines from the enginebaypanel to the front disks.
first comes the flexible hydraulic hose and the the 4,75mm iron-brakeline to the caliper..
does some one have a set of pictures to get the routing right.
regards A
Hi Lemans, mooie kleur!
Try the link below:
I am in the process of rewiring my project and try to learn from this, I have noticed that this part of the car is un-fused!
The wire through the steering rod is a actually live wire 12V+ and when connected to ground a current will flow switching the relay to sound the horn. Disconnecting this wire will have no effect and horn will not sound when pressing the switch on the steering wheel. A shortage of the wire to the steering rod will force a current through the bearing, if the connection is good will sound the horn continuously.
Am I seeing this correct?
yours is correct, depending on which wiringdiagramme you use the horns are fused/not fused. but on mine the DPO rewired the horns differently, leading to this damage
Discussion Starter #12
yesterday we decided on the upholstery-colour.
red/brown leather for the front seat and door covers, officially paloma "inca 05599"
seats will be finished by our local firm at the end of march
Discussion Starter #13
been a while but progress is being made.
rear axle refurbished and fitted.
I don't haven any pictures of repairing the axle but all bearings are renewed. A few of you have used heat to fit the shrinkrings on the drive-shafts. I was able to just press them on with a garage-size hydraulic press and a tube of the correct length.
1619270
Discussion Starter #14
now I searching for these, apperently locknuts but I can't find them anywhere.
does someone have a hint where to order
1619278
Discussion Starter #16
yes these are the ones, thanks for your quick replay, even Brezan didn't recognize them.
Watching with interest
Discussion Starter #18
Bella is back on tires. After 8 years of welding cradle, paint shop cradle and tripods shes back on tires. on beercrates as I still have to work her underside.
1969 GTV 1750 Australia
Interesting 'hoist' Crates are full too.
1 - 20 of 25 Posts
