In my last post, I introduced my "new" 158 Giulietta Spider Veloce. In this one, I'm proposing a restoration "roadmap" and my goals. In reading posts by others, I've seen comments about original versus performance or reliability updates, but I haven't seen everything compiled in one place. I wrote this up for my own benefit to get my head around the project upcoming, but I thought others might find some interest and I'd certainly like to hear comments from others.
Goals
The first thing is what are my goals for this restoration? Do I want to return the car to "original", make it better than original, do modern upgrades? That really depends on my use. So here are some thoughts.
So, what does this all mean? Well to me it means having a car that retains it's value through the original engine, un-molested chassis and body and a box of parts that can be put back on the car to make it truly original. But it also means that I hopefully end up with a car that can be driven reliably, safely and without fear of being stranded. It's no fun to work on a car on the side of the road or having to wait for AAA and just hoping you have cell phone coverage to make the call.
Restoration Roadmap
Given the goals above, here is what I am thinking about as a restoration roadmap. Most of the questions below are to myself for further research, but of course comments and advice is very much welcomed.
Chassis and Body - Keep as original as possible. The only change I am anticipating here is chassis reinforcement in the rear trailing arm mounts as have been described elsewhere on the forum. Sheet metal and rust repairs done properly. No 1/4 inch thick slabs of bondo or riveted patch panels please. Nice re-chrome job and great paint.
Do folks recommend any other areas of strengthening or stiffening for safety or performance reasons?
Drive Train - I have an original tunnel case transmission 4 speed. I don't know what I have from a final gear ratio perspective but for now I am assuming I have what was standard on the Veloce. I've read about the benefits of the 5 speed and easier freeway cruising and less punishment to the engine. But, I really think I want to stay with the original tunnel case transmission. So, I believe this limits me to a 4 speed.
Are there any suggestions on how to optimize engine and drive train performance given I want to stay with the original transmission? See below on going to the 1400 kit, but if I do that, are there any recommendations regarding the transmission? Any changes suggested on the rear end?
Brakes - No changes here. Everything I have read is that the standard drum brakes on these early AR cars are fine. Given the condition of the car, I will be replacing all the brake lines and doing the appropriate level of rebuild on the master cylinder and the brake pistons themselves.
One question here is whether I should stay with DOT3 or go with DOT5 brake fluid. I have read that DOT5 is not compatible with period materials, but couldn't I just make sure I rebuild everything with materials that are compatible with DOT5? The only reason I am thinking this way is that I have read that the maintenance schedule for DOT5 is more flexible than DOT3. This is not a big issue and I can go either way. I'd like to hear opinions on this.
Tires and Wheels - It appears my car is coming with 5 Fergat wheels. This is good, but I have read on the BB that some folks consider period wheels to be not as robust and safe as new alloy wheels. So, I am considering new wheels. As for tires, I would like to keep a somewhat period looking profile. No 17 inch wheels and low profile tires. I know there are options out there so I think this is not a big issue.
Is there a consensus on an alloy wheel/tire combo with good performance but also acceptable somewhat period look? I am not adverse to a little bit more width, but I don't want to deal with wheel well rubbing or bottoming out.
Engine - Since this is a matching numbers engine, I don't want to molest it. But, reversible changes are okay. The engine is completely apart so now is the time for reversible engine upgrades. I haven't looked at the cams yet so I don't know what I have but right now I am assuming Veloce cams. From a performance standpoint, many people recommend the 1400 kit. I've read about this being done to a 101 engine but what about a 750?
Will a 750 engine with a 1400 kit and Veloce cams combined with the stock drivetrain as described above be a good combo? Any other suggestions in this area?
Intake/Carbs - Unfortunately my Veloce is missing the DCO3 carbs and the original 750 Veloce intake manifold. I think I can source these items, but these three parts could approach a significant portion of what I paid for the whole car!! I think I do need to get these items for investment purposes anyway but here's the question on the fuel delivery system.
I have heard that the older DCO3 carbs are not so great because they are sand cast (leaky?) and also because they use bushings instead of bearings there might be wear and reliability issues. Since I don't have them or the intake anyway, for daily driving, reliability and performance would it be better to get a 101 intake and DCOE carbs and go with the 101 setup on the 750 engine? Any other suggestions on the intake side of things?
Under Hood Electrical/Ignition - In this area, I am thinking about two things for reliability. First, I am considering an Ignitor electronic ignition from Pertronix. Second, I am considering putting in the Denso alternator instead of the stock generator. My goal with both of these items is to add some reliability and lessen the maintenance aspects.
I know there is some debate about these items. Comments, suggestions? Do both of these items work in a 750? Other upgrades to consider in the Electrical/Ignition area?
Other Electrical - Again, in this area I am interested in reliability and I want to try to minimize squirrelly electrical problems. I'm hoping I can have it covered by installing a new wiring harness and do a good job of installing the electrical bits and pieces.
Are there other suggestions in the electrical area? I read I think in the Benson book that some people ran a heavy ground wire from the rear battery up to the engine compartment? Is this suggested? What about fusing? I am not adverse to even putting in a modern ATO/ATC fuse block if that improves reliability. This is one item that could easily be reversed. Is this overkill?
Interior - Okay so first of all, no modern iPod equipped stereo systems with subwoofers in the back.
In fact, I will most likely just remove the period radio that is in the car and put in a radio blocking plate. The only change that I am thinking about for the interior is drilling holes and putting in the proper studs for seat belts. I have read that some people argue against seat belts in an open roadster that does not have a roll bar cage, but I think I would feel more safe with lap belts. Other than that, I can't think of anything on the interior.
Is there a consensus on lap belts? Any other interior suggestions? BTW, I have read that for an open car, vinyl is much better than leather because it holds up better and you don't have the maintenance issues you have with leather in the sun? Any comments on this?
I think I've pretty much covered the car, head to toe? What did I miss? The goal is a car that is fun, safe and easy to drive and maintain. I'm thinking that if I do all of the above, I will end up with a good result. Other than biting off a lot to chew, what do you think?
Thanks for reading this long post.
Paul
Goals
- I have no desire to show the car or enter it in any sort of judging so no need to research and place every label on every hose. I admire that dedication, but I just don't have the patience for it.
- But, I would like to have it look pretty original from the outside. Why mess with the beauty of the original design.
- I'm not going through all of this work to just sell it for profit or auction it off. I want to keep it and drive it for a long time.
- I want to DRIVE the car. No trailer queen here. The goal is to have it be a daily driver in the summer time and probably garaged in the winter unless it's a nice day.
- Because of this, I want the car to be reliable and so modern updates that significantly improve reliability are in the game as long as they can be reversed.
- In fact, pretty much any change that is subtle or hidden is game, as long as they can be reversed by removing the changed part and installing the original part.
- I'm interested in performance upgrades as well, but they need to be reversible as described above.
- Safety upgrades are one area where a permanent change is okay. Things like drilling holes for seat belts or welding in plate to stiffen up the rear trailing arm mounts are okay.
Restoration Roadmap
Paul
