Good evening fellow travelers.
Remember the engine that ate itself a couple of weeks before the 2019 CI? Well, it's nearly back together.
I had the crank and rod reworked, bought all new bearings, found a better looking oil pump in my box labeled "oil systems", rodded out and air-blew (blowed?) ALL of the galleries in both crank and block, installed threaded plugs in the galley holes, both crank and block, cleaned the cRaP out of everything, and put it all back together.
I've got two spare starters, but both of them have dead solenoids. Dang. So, I need two and Jay needs at least one. Ideas? Anyway...
I bolted up one using safety wire to keep it engaged, and cranked until I got pressure. 70psi! My method of priming the pump was a little different this time. As the pressure gauge outlet hole is AFTER the oil filter, I rolled the engine upside down with the oil pan off, and poured oil into the pickup snorkel while periodically running the starter. It took a while to fill the oil filter canister, but after a while I could tell it was feeding the galleries. Bolted up the oil pan, rolled it over, and cranked until the pressure came up. This engine never made 70 psi, so whatever was the problem appears to now be cured. Either that, or NONE of moving bits are receiving oil and the pressure is due to a complete deadhead. I know that's not the case, as I could see oil coming from around the crank bearings while it was upside down (one of the reasons for doing the priming while upside down and naked), and upon investigating the cams, they were fully bathed in fresh oil. AND, no leaks even though having upside down, the better to reveal them.
I've got the bell housing cleaned up and fitted with new rear support bushings (what a PITA - but I have tools).
In digging through boxes, I found four F&S pressure plates, and five or six discs. I'm going to try and find a rebuilder to bring some or all of that back to RTU status (ready-to-use). I'll need to keep two pressure plates, and the other two will be available for whatever they cost me to overhaul plus a little more to cover the shipping and hassle factor. Does anyone remember the California shop that has done these before?
Meanwhile, back at the ranch...
My new local (Reno) machine shop is continuing to impress. They are going through all the large parts for a 59 2000 engine. Those are the early ones with more or less a 1900 bottom end. I've never redone one of those before, and it's interesting to see the small differences compared with a later 102 engine. The rods appear frail (and lighter) than the later 2000 rods, plus, of course, the rear main bearing. I can see why they changed that. Lots of 90 degree angles subject to stress risers back there. Although I've never heard of one blowing up due to the rear main bearing configuration, I think the original engine in 00072 launched a rod through the case, and it would have been an early engine. I expect to receive all the stuff back from the machine shop about the time I'm swiveling this one off to its next station.
By the way, I'm going to end up with an extra early crankshaft, all turned and ready for use, WITH bearings, galleys rodded, and threaded plugs installed. Jay whispered to me that the early crank can be used in both early and late cases, but the late crank won't fit an early case. I knew that, as I tested the idea. Won't fit.
Speaking of extra parts, the engine I'm building now will be mated up with a recently overhauled (L. Dickman jr) trans, fresh clutch, etc, and installed into my display case. Given my 2-year plan to disappear into the Andes, I'll be posting the entire engine and trans kit, in the display case, on BaT, if they'll accept it. I'm building up the engine with an FNM manifold and dual 40 Webers. I can include a Solex manifold if the future owner wants, but although I have them, I'm not sure I'll have time to rebuild a set of carbs to match. There's only so many days remaining....
So many Alfas, so little time.
My grandson at about six or seven. Quite the helper with backing up blind nuts and bolt heads.
Same grandson, now a Junior in High School. Varsity football letter from his Sophomore year, soon to be joined by a letter from being in the top Band, including honor band.
Wants nothing to do with cars, although he expressed an interest in the 916. His dad bought him a dirt bike for Xmas. Oh well, I won't be around if he lives long enough to make great grand kids.
